Direct Access to the Custom Devices Feature
Monitoring custom devices in Dynatrace provides valuable insights into the performance and health of specific devices, including SAP applications that require Real User Monitoring.
Currently, to check Custom Devices, one needs to navigate to Technologies & Processes from the menu or use dashboards. If there were direct access to Custom Devices in the menu bar, it would significantly enhance efficiency for those who frequently use this feature.
I do not see an entry there. You can raise a product idea about it.
Best regards
Product idea has been raised.
