Hi Team,
Is it possible to disable alerting for the Builtin metric of GC in Java, tech.jvm.memory.gc.suspensionTime?
If that is not possible, can we disable the metric itself, like not collect data for GC, only for Java processes?
Vishnu
Hi Team,
Vishnu
You can disable or finetune the settings it in the anomaly detection settings. Either globally, on a host or for a host group. It’s not a setting on the process/process group, but on the host.
@Islam_Zedan and @Julius_Loman , thanks for the replies.
I dont want to disable GC collection for all Technolgies, only want to do so for Java. I did refer to the high GC settings, but that wont work for my case.
