Hi all.
In my customer, we are ingesting events from GitHub, but they are not mapped to any dt_entity.
Is there a view where all these ingested events can be seen?
We are following Example #2 in this blog
Thanks in advanced
BR
Jar
Hi all.
Thanks in advanced
BR
Jar
Hi, @JAR1 , you need a targeted host or service to add the events:
Also to consolidate you can try to create a CUSTOM_DEVICE named GitHub and try to send the supported events there.
Now that Dynatrace support SDLC Events is this method needed?
Hi @JAR1 , also helpful to check: Analyze SDLC events from your pipeline — Dynatrace Docs
Best, Wolfgang
