If you ingest events using Events API v2 and it is linked to “dt.entity.environment”. Can we view those events in the Dynatrace UI or only via API?
We cannot use DQL or notebooks yet. My question is more if we have a section where we can see it instead of API. IT is a SaaS tenant without Grail.
Best regards
Try with DQL and fetch events.
Hi Paco!!
Let me update my question, it is not a tenant grail enabled yet. We cannot use DQL.
It is just to confirm if event information is visible in some section in the UI, when it is ingested in tenant level instead of anb entity.
DQL / Notebooks are not available yet.
Best regards
AFAIK only with the API.
I would suggest linking it to a custom device.
