Hello i’ve searched everything and nowhere says where i can create secrets foe the integration with github in order to get notified for every change i do in the code from dynatrace. It says we need to complete these secerets in githab DYNATRACE_URL_GEN3: ${{ secrets.DYNATRACE_URL_GEN3 }}
ACCOUNT_URN: ${{ secrets.ACCOUNT_URN }}
DYNATRACE_CLIENT_ID: ${{ secrets.DYNATRACE_CLIENT_ID }}
DYNATRACE_SECRET: ${{ secrets.DYNATRACE_SECRET }}
DYNATRACE_SSO_URL: ${{ secrets.DYNATRACE_SSO_URL }}
where do we find each one? Especially DYNATRACE_URL_GEN3
Hello @Manosirigosdyn7
I need a bit more details to help you.
- Can you please point me to the documentation that describes how to complete the secrets in GitHub? I`m curious where this information is published because it looks that it is misleading.
- The secret details (CLIENT_ID, SECRET, URN, etc.) you are looking for are required for an OAuth communication. This is however not needed for a GitHub integration. We recommend using GitHub Webhooks instead. Are you planning to integrate GitHub into Dynatrace using Webhooks? Webhooks documentation - GitHub Docs
BR, Johannes
Hello Johannes,
what we want is the following:
when for example we make a new commit on github, we want an event to be sent to dynatrace and trigger a workflow. We tried this : GitHub - Dynatrace/dynatrace-automation-tools · GitHub
Thanks. No I understand the use case.
Instead of using the dynatrace-automation-tools, would it be an option for you to ingest the GitHub webhooks on the https://{your-environment-id}.live.dynatrace.com/platform/ingest/v1/events.sdlc endpoint?
Advantage: You don`t need to change your GitHub workflows.
Would this approach work for you?
