Dynatrace is being tested on our standalone Solaris environment and we are getting all the typical metrics being reported, which is great, but is there a way for Dynatrace to monitor hardware failures…ie Fan failures, PS failures and Metadevice (SVM) failures? We used to use Nagios, which worked great for running a script and reporting on the return, OK or Failure.
Thank you.
Hi.
You can try to build your own SNMP extension.
Please check SNMP data source — Dynatrace Docs
And since you are already have scripts, maybe you can adapt them to ingest OK or KO to Dynatrace via Metrics API - POST ingest data points.
Best regards
Hello @SSC_Solaris
There is another option to submit your request to Extension team to create a dedicated extension that cover current and future monitoring requirements in addition to the applicable solutions provided by @AntonPineiro and @PacoPorro :dynamight:
if there is a development team to build the extension.
Regarding the Metrics API - POST ingest data points:
KR,
Peter
