We’re trying to do reverse engineering in order to define the right custom service to get end to end traces. Seems like this framework is working differently with the rabbitMQ messages.
We also use it in a .net environment. Most of the communication is done using Masstransit.
It’s been quite late for years now unfortunately. So far it is not supported. Which makes it quite difficult to operate.
You can put in a request for it and if it’s voted down it’ll be marked down…
