Dynatrace Lambda environment variables in CLearText
The Lambda environment variables which include Tokens are in clear text and we were wondering if DynaTrace can retrieve it from secrets manager or decrypt a KMS encrypted variable? Does DynaTrace support this capability? We are not comfortable with tokens in clear text in Lambda environment vars
WE use terraform for IAC.
Any recommendations, suggestions are appreciated?
Hello, our team creates variables to avoid as you indicate to send tokens in clear text. We are also using Terraform.
