Dynatrace Managed Cluster Migration
Hii ,
How can i do my managed cluster migration from a virtual AWS environment to an On-premise environment on dynatrace please let me know all the process and documents required for this and help me know the what are the configuration and dataypes needed so we can do the  migration.
Thank You
You can find the answer here: Migrate a cluster — Dynatrace Managed Docs
Let us know if you need more than that or there are still open questions.
How to change the default data paths for Cluster Migration
When you migrate by replicating nodes - Pass additional installation parameters to the installer - Customize Managed Cluster installation — Dynatrace Managed Docs
If you use backup/restore then change storage location - Change storage location — Dynatrace Managed Docs
