In the Dynatrace Managed deployment scenarios I can see that all the port configurations are marked with an arrow. Does it mean all of these configurations can be just outbound and that is all needed? Or do they need to be two-way?
For example; Managed Node ----443----> Mission Control
https://dt-cdn.net/images/man-ha-setup-2461e8a9c1.svg
Exactly as allows tell what is the traffic direction. Dynatrace Managed requires only an outbound connection to Mission Control. Incoming connection can be closed externally.
Here are two useful links that detail the ports Dynatrace uses and what they use them for in case you have further questions or just want to bookmark them:
Cluster node ports
For security reasons, we created a rule at the FW level of only outgoing traffic to mission control IPs.
Regard!
