Dynatrace Siebel Implementation
Has anyone implemented Dynatrace on a Siebel-based application? If yes, can you please share the screenshots of the metrics that are being reported in the UI? Also, if the extensions are also used, then that information is also helpful.
Have you looked into this one?
Also is this question a duplicate to the https://community.dynatrace.com/t5/Dynatrace-Open-Q-A/What-metrics-are-collected-for-a-Siebel-based-application-in/m-p/192969#M22272 ?
@Radoslaw_Szulgo
I did look into this - https://www.dynatrace.com/hub/detail/siebel/ . I want to see an example of real time implementation of Dynatrace on a Seibel based app . I am looking for any case study if anyone has implemented in the past .
Thanks ,
Manupriya
For the record - the real user monitoring / digital experience monitoring with Dynatrace on Siebel is also possible.
Thank you @Julius_Loman  for the info . Have you done any such implementation in the past . Can you share any screenshots of the same .
Yes, we did that for several customers. I’m talking about Siebel with Open UI (Siebel 8+) with a supported webserver in front of siebel (Oracle HTTP Server, Apache, IHS, … ). Tracking user experience and errors works well, for some very detailed insights some minor enhancements in the Siebel One UI is required. Also setting up Request Attributes will bring you insight into the requests and you are able to track down any performance issues to particular Siebel actions and records.
Hi There Julius, I have a client interested in Siebel monitoring as well.
However I can no longer find anything related to Siebel in the Dynatrace HUB page.
Can you please guide me?
Thank you in advance!
