Hello there!
I want to know if there is some way to observe SIEBEL platform. A few weeks ago I was with a Client and we check in the Dynatrace Hub that there is a SIEBEL extension available.
Last friday we came back to see how to install it and the extension was retired from the HUB.
Does any one know if there’s going to be a newer version or some to monitor SIEBEL?
The Siebel extension was removed from the hub as it will stop working in a couple of months. It was not migrated to the new framework because it was very complex to set up on the Siebel side, with only a handful customers managing to do it.
If you need Siebel monitoring I recommend to reach out to your Dynatrace contact to see if what we have might be a fit for you.
Hello.
Classic deep monitoring via OneAgent with application injection, service monitor isn’t supported yet?
OneAgent should work however it wont trace between Web and App Servers due to SISNAPI Protocol
