Monitoring of Cisco ISE - Identity Services Engine
Does Dynatrace have an extension purely for Cisco ISE?
I see Splunk (yes, blasphemy :grinning_face_with_smiling_eyes: ) has this Youtube which explains quite well how to install their monitoring app for Cisco ISE but was hoping their was something much better by Dynatrace.
I know in Extensions there is Cisco devices but wanted something like this with good clear instructions on how to best achieve monitoring on the ISE devices.
I do not see specific instructions on Hub. I would say no extension purely for Cisco ISE.
Best regards
Well, Splunk is now a Cisco company, so it makes perfect sense that it could monitor Cisco ISE.
In minute 18:30 they send ICE Syslog to Splunk, you also can do this with Dynatrace. I leave you the link. Syslog ingestion with ActiveGate — Dynatrace Docs
From that point much more of what is explained can be do it also with DQL.
Hi @tabpws,
We had this use case for Cisco ISE Monitoring and created our own 2.0 extension via SNMP datasource.
