For an environment with 1000+ domains, I would definitely avoid managing SSL monitors manually.
My recommendation would be to treat SSL monitors as Infrastructure as Code and manage them with Terraform (preferred) or Monaco.
Terraform is particularly well suited because you can keep your inventory (CSV, YAML, JSON, CMDB export, etc.) outside of Dynatrace and use for_each to automatically create one monitor per domain. This makes onboarding and offboarding as simple as updating the inventory and re-running the deployment.
For example, we use a very similar approach for managing Dynatrace Management Zones. The configuration is generated from a table in tfvars, and Terraform iterates over the entries to create the required resources dynamically. Here’s a simplified example of using a dynamic block:
You could apply the same concept to SSL monitors—store all domains in a variable or data file and let Terraform create or remove the monitors automatically. This approach scales much better than relying on manual configuration or bulk imports and keeps your Dynatrace configuration synchronized with your source of truth.
Of course, you can also automate this directly through the Dynatrace API if you prefer to build your own provisioning process. The Synthetic Monitors API supports creating, updating, deleting, and listing monitors, so it’s perfectly possible to synchronize your inventory from a CMDB, DNS, or another source of truth. Synthetic API v2
That said, I’d still lean towards Terraform (or Monaco) for long-term maintainability. Using Terraform with for_each gives you version-controlled, declarative configuration and makes onboarding/offboarding as simple as updating your inventory and applying the changes, rather than maintaining imperative API scripts.
