EasyTravel requirements
Hello, I want to install Easytravel in restricted environment. Can you please help in sharing inputs on below -
  • Perimeter level controls (Firewall etc.)
  • The ports and protocols required for communication
  • A brief on the type of data involved in the flow
  • Does this application itself requires internet access? (Oneagent will need which is already mentioned to sec team)
Thank you in advance
@pradeepkadam Please see below all requirements are captured here
https://community.dynatrace.com/t5/Start-with-Dynatrace/easyTravel-Documentation-and-Download/m-p/181271
Hi, in general, easyTravel does not need internet access. You can start it with runEasyTravelNoGUI.sh script.
Ports used for communication between processes: 8080, 8180, 8280, 9080, 9180, 9280, 8091, 8191, 8092, 1527, 8079, 9079.
Launcher UI is available on port 8094.
Ports for .NET components (Windows only): 9000, 9010, 9020, 8999
Data exchanged: HTML & XML.
