Events in Host View in infrastructure mode
we can see events in host view in infrastructure mode .  is there any option to get these in  dashboard .
i need in a dashboard when i select a host, it should list out events  for specific timeperiod
Hi!
In gen2 dashboard it is not possible
in gen3 dashboard with grail it is possible
fetch events
thank you for your reply .  i am trying to extracts events via API .    in host home page in last 2hours . it says
204 custom info and 6 process restart . on event api dump , it just has "custom info " only.
Am i missing something
Sorry i am not understanding, which kind of events you want to extract and how
Events in V1 can only be seen for Kubernetes segments. If you are looking to export events overall via the V2 API. But as @yanezza stated, were having trouble following the ask.
