Is there any way to track all my host events on dashboard, can someone please help me on this
Hi @hemanth
At the moment there is no such view available. You can configure Markdown Tile to link to relevant cockpits e.g. Process Crashes.
You can try to pull the rest of the information with the help of metrics, but it will rather be statistical information without Event description.
Radek
I have just not explore it yet but I do not know if that is possible using Grail + DQL.
Best regards
Yes, it’s possible with Grail/DQL.
I’ll do some research on my own to find the correct syntax
Yes, only this only works for the SaaS version.
We don’t know what version @hemanth using :slightly_smiling_face:
@radek_jasinski using SaaS version .
yes, please that would helpful @gbaudart
Hi @hemanth
You may try :
fetch events
| filter dt.entity.host == "HOST-DA3D0FBDE137805E"
And you can display the count histogram with timestamps :
fetch events
| summarize count(), by:{timestamp}
let me know if this ok for you
