Expired certificate - older Oracle extension versions
as I see this message I was wondering how much time I have until version 2.5.1 will be outdated as 1.4.0?
Heya,
Error seems not look like a certificate expiry with the Extension related or the version. Otherwise you can try with the latest version being installed on the environment and check if its still persist. With the Oracle DB insight extension its been 3.x series as latest. Also would be worth if you give a try to check the Self signed certificate in AG.
