Hello community, how are you? I have a new question. When we have a multidimensional analysis with more than 100 results and we want to export it, only 100 results are exported. How can we make it export all the results?
This is a limitation of the MDA. The maximum is 100.
One of the workarounds would be to create a metric from the MDA and create it with a higher dimension number.
You will still have to extract from this metric.
