Currently when exporting data from Data Explorer into CSV the result is limited to 100 entries.
Could you add possibility to remove CSV export limit or add possibility to configure higher limit for CSV export.
PS. I know that using API I can export metric values into CSV without limit - but I cannot offer this solution to managers and users without development background.
I’m on Managed version 1.262.
- After removing “:limit(100)” from query still only 100 entries is exported to CSV
- There is no “No Limit” option for Limit parameter
can you upgrade to 1.266?
https://www.dynatrace.com/support/help/whats-new/release-notes/managed/sprint-266
https://www.dynatrace.com/support/help/whats-new/release-notes/saas/sprint-266
Data explorer and dashboard table enhancements
Platform | Data explorer
We have made the following improvements to the table visualization:
- Columns: In the Data explorer table visualization, use the checkboxes in the Columns section to enable and disable the display of columns. These selections are reflected in the resulting dashboard tiles.
- Rows: In the Data explorer, you can remove the limit to see more than 100 rows.
- Pages: In the Data explorer and resulting dashboard table tiles, tables are automatically paginated. Use the controls under the table to page through tables.
New limit feature is mentioned in SaaS release notes only. Does it mean that Managed will not have possibility to remove limit?
Based on what I see:
These release notes relate to Dynatrace Managed specific changes. To learn about general Dynatrace changes included in this Dynatrace Managed release, see:
So appears managed gets SaaS updates for general stuff like this.
