I am currently using Couchbase 7.x as my database, and it exposes metrics through the Prometheus Node Exporter on the /metrics endpoint, the database is deployed on a virtual machine hosted in the cloud.
I have been searching for materials or extensions that explain how to retrieve these metrics using Dynatrace, but I have been unsuccessful in finding any.
Additionally, I wanted to inquire if there is a way to simplify the process of importing these metrics into Dynatrace. Is there a method similar to the RabbitMQ extension where manual coding of each metric is not required?
Thank you for your assistance.
