Hi
I am trying to get confluent metrics from Prometheus.
I saw them in the documentation (https://www.dynatrace.com/support/help/extend-dynatrace/extensions20/data-sources/prometheus-extensions/prometheus-schema-reference)&data=05%7C01%7Cgofman.anatoly%40il.zim.com%7Cf328fa9cf7fa4718d2d708da327295a0%7Cc3debccf0f644fc98686edeedbe9f513%7C0%7C0%7C637877764954814690%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=agTA0j6HeRVBsvxvjwPe8k0c%2BJ0J2rcL4KatfZ441V0%3D&reserved=0) that we can either use /metrics in the URL as the endpoint, or /api/v1/targets
Currently, I am having issues with my /metrics endpoint, so I wanted to know how I can extract the same metrics using /api/v1/targets? Is that possible or does it return different data than the metrics I am looking for?
Thanks in advance
Anatoly.
