Extension upgrades vs ActiveGate versions
Prior to performing upgrades on extensions is it possible to have the ‘required’ AG version listed in the release notes please.
I have had scenarios where I have upgraded to the latest Extension version to only find it doesn’t work because the AG is not at the desired version.
If we had this in the release notes it would really help.
Cheers, Jamie
Please raise it as a product idea and we will route it to the correct team.
raised under Extension Upgrades v’s AG Versions - Dynatrace Community
