Hello, I hope you are all doing well!
Was just checking in to see if anyone has had experience with the file monitoring system extension? Can you please share any advice?
Josh
Josh
Hi
everything should be explained on the Hub tile.
Flo
Iâve installed it but getting the following error even though Iâve put all the config settings in the UI and saved.
2022-08-05 17:20:58.642 UTC [00007602] severe [native] 140043095779072(MainThread) - [create_config] Incomplete config for plugin: PluginInfo(name=âcustom.python.fileChecker-MINTâ, reported_name=âcustom.python.fileChecker-MINTâ, version=â1.2â, directory=â/opt/dynatrace/oneagent/plugin_deployment/custom.python.fileChecker-MINTâ package=âfileChecker-MINTâ), missing_properties: {âtenant_tokenâ, âdebugâ, âtenant_urlâ, âpaths_filesâ, âpaths_countâ, âpaths_ageâ, âinclude_foldersâ, âpaths_foldersâ, âpaths_mountâ, âpaths_sizeâ, âlatest_fileâ}
This message can appear in 2 cases. The extension is available on the local machine but not deployed via the UI or it appears once before the extension module actually deploys the extension.
If you see this message: [info] Running the file checks, the extension is deployed as expected.
Just started to use this extension, seems to work great. I really like the host group based deployment, will allow config of a lot of servers quickly. Getting counts and sizes so far.
Good to hear! Iâm sure that the people working on the framework such as @Lukasz_Be would love to capture that quote ![]()
Do you have to remove all remnants of the old custom.python.fileChecker-MINTâ, version=â1.2â? I installed the new Filesystem monitoring / Extension v2 0.2.6 but getting ERROR when attempting to configure any server for a mount check.
You donât have to remove the old one but Iâd recommend it to not cause confusion.
If the new extension doesnât work, please have a look at the extension log files on the OneAgent (either directly or by clicking on âERRORâ to open up the log viewer). If that doesnât solve it, open up a support case.
Sorry I wasnât at the min required oneagent version⌠however I am now and itâs working but I donât see in the docs that you can input multiple directories using comma separated like you could with the older versions. Is that still possible?
You can simply add more checks to one configuration, keeping it much less error prone than the old method.
