Formating output biz event
i want format result  query on summarize, the default it’s 2.34K i need number detail, example : 2341.-
Thans a lots
Hi Ellery,
I do not think that there is a way currently to format the ‘Single Value’ to not append the ‘k’; however, if you look at the value under the ‘Table’ tab, it should show you the detailed number that was collected from the count() call.
I will also add that in Grail Notebooks, you are able to add more Formatting options as oppose to the Advanced Views in logs. The output there should show you the value as a single number without the appending ‘k’ if you deselect ‘View value formatter’.
Cheers,
Taylor
