Hi Team,
How can I remove all other modules except ‘Beacon Forwarder’ from ActiveGate?
I’m not getting option to remove them from custom.properties.
AK
You can add the following to the custom.properties file:
[collector]
restInterface = false
MSGrouter = false
[vmware_monitoring]
vmware_monitoring_enabled = false
See docs.
Sia
If you’re in a Windows environment, I wrote a little piece on how you can optimize resource usage in an ActiveGate deployment:
https://community.dynatrace.com/t5/Dynatrace-tips/Optimize-Windows-ActiveGates-resource-usage/m-p/206845
BTW, you have to disable all of the modules, and then restart AG.
