How to do navigation via button in react - app engine
I wanted to navigate to the next page via a button. It will be via the onSelect method.
How should I exactly implement it specifically the navigation via all the buttons including return?
<span><TitleBar.Suffix><br></span><span> <ButtonWrapper><br></span><span> <Button </span>prefixIcon<span>=</span>{<span><HomeIcon /></span>} variant<span>="minimal" </span><span>><br></span> Home<br><span></Button><br></span><span> <Button </span>prefixIcon<span>=</span>{<span><DataTableIcon /></span>} variant<span>="minimal"</span><span>><br></span> Software<br><span></Button><br></span><span> <Button </span>prefixIcon<span>=</span>{<span><StackedBarChartIcon /></span>} variant<span>="minimal"</span><span>><br></span> Analytics<br><span></Button><br></span><span><br></span><span> </ButtonWrapper><br></span><span></TitleBar.Suffix></span>
Hi @kwangxi :waving_hand:
Sorry for the late reply, and maybe you’ve already solved this.
If not, I’ll give you a few options. The most straightforward solution is to create a function to override location, and pass it as event handler on the button component:
const clickHandler = () => {
  location.href = "https://google.com"
<Button onClick="clickHandler()">
  Click Me
</Button>
The best practice for this however, is to either use a component which allows for this in it’s interface, or a router. For the former, the Strato design system has the <Link /> component you can use. For the latter, you can use React Router, which is also included when you bootstrap your app with dt-app.
