Thanks for the code snippet. I tried with the latest Strato and I can’t replicate your issue. Can you also tell me the screen width and also version numbers of Strato packages?
I found the problem ! Thank you for your answer, it put me on the right track
It was a dumb mistake : the appHeader was in a <Flex> with the help menu and this caused the appHeader to have a small space allocated and have a weird display.
