How to get Dynatrace Managed Cluster Token Automatically after installation?
I am trying to automate my deployment of Dynatrace Managed, and the Cluster API seems useful for most of the setup, but I’m having trouble automating getting a token to access the Cluster API.
The Cluster API has an endpoint to create new Tokens, but I need a Token to authorize and use that endpoint, so it’s a circular dependency.
I noticed an “afterInstallation” token in the Cluster Management Console (CMC), is there any way I might be able to retrieve that token? My idea was to somehow grab the “afterInstallation” token right after installing dynatrace managed, but I don’t know how.
I have ssh access to the nodes in the cluster and the admin username/password. The manual way would be to login to the CMC and go to Settings > API Tokens > Cluster tokens > Generate token.
Is there a way to generate or obtain a token via CLI that doesn’t depend on already having a token?
(Question originally posted on: How to get Dynatrace Managed Cluster Token Automatically after installation? - Stack Overflow)
You can use this endpoint to create a new cluster token
https://www.dynatrace.com/support/help/shortlink/api-cluster-tokens-create-new
For that, you need to generate an API token with ClusterTokenManagement permission, please check the below document.
BR,
Islam
