Precautions for cluster migration, whether there is a cluster migration operation manual and how to migrate. Does centos 7.4 support migration between redhat 9.4? Check whether the system version of the ActiveGate server needs to be upgraded during the migration
In general, if you are basing it on supported versions of the operating system, this should not cause any problems.
However, I recommend that you make a backup (or snapshot of the virtual machine) before migration.
Radek
