In the Synthetic monitor, how can I specify the frequency hours as 8 hours or 12 hours? Please guide me.
Hi @reginjenci,
for an existing monitor you can click on “edit” and select “Frequency and locations” in the monitor settings menu.
There you can change the frequency. For http monitors it is possible to choose between 1 min and 60 min. For browser monitors it is to choose possible between 5 min and 4 hours.
If you only want to run the monitor every 8 or 12 hours, you might be able to solve it using the on-demand function. Please also check the API section in the linked documentation.
Thanks for the reply. I need the monitors to be executed every 8 hours or 12 hours. Is there is an option to do that.
As a work around you can also set up a reoccurring maintenance window that will suppress runs at a certain time. then allow it to run at another time. Dynatrace does not have the ability to set larger intervals as you are requesting, you can put in a RFE for that function though and maybe it will be provided in the next few updates
