how work custom disk-detection rules
HI all.
We have a question about the functioning in Anomaly detection.
In our client we have several custom rules created:
Details custom rule 1:
Details custom rule 2:
Our question is whether these 2 rules are a set. That is, they are like an “OR” or as “AND” ??
thanks in advanced.
Jose A
It’s OR logic. To make it more specific, you can even use tags or host group.
Thanks Christopher.
One more doubt: to exclude a specific unit I have created a rule with a threshold of 0%
i think, with this setting the alarm will never start. Is it correct?
Thanks again.
Jose A
You’re right, i.e. if you put 0.2% then the disk space should be 99.9% full before it gets detected as a problem (and subsequently alert).
