Can someone confirm, that the custom disk-detection rules overwrite other settings? So e.g.
1. I have a host that’s not using host group anomaly detection, it has a customized setup.
2. Then I modify one specific drive to have low disk space detection off.
3. If a custom disk-detection rule applies to that host group and that drive, it will essentially re-enable that drive’s low disk space detection / alerting?
That is at least what it appears to me. That’s a bit problematic, because the custom rules are pretty rigid, and don’t allow the exclusion of single hosts or drives. So you can’t use them as a general template and then do some modifications host per host and drive per drive. It’s starting to look easier to just ditch the custom rules, and manually modify each host.
