IBM MQ remote extension - topology mapping error
I’m trying to use the IBM extension remotely on a queue manager running on Linux RHEL ppcle (PowerPC10 Little Endian).
The extension manages to authenticate but I have got a error message: An error occurred sending queue manager STGP topology mapping to environment. Response code: 404. {“error”:{“code”:404,“message”:“HTTP 404 Not Found”}}. I have already tried a lots with no result, even with the support. How to get by ?
Regards
Gautier Bégin
Hi @gautier_begin,  hope you are doing well.
You can specify which event property should be taken into account for defining the Topology of the discovered Queue component and define in the Generic Types. Doc about the topology configuration as available here: https://docs.dynatrace.com/docs/shortlink/custom-topology
Choose as many as properties, entities which needs to be mapped and create the entity type for creating the Topology Mapping.
