How does Dynatrace identify the ingoing and outgoing connections for Host? Is it based on purepath data?
Hello @hqlee ,
To put it correctly. Incoming and outgoing connection is based upon process connection interlink.
Say if process A calls process B then host1 which are running on process A will show as incoming connection host2.
click on any host --> click on … 3 dot --> click on analyze process connection
Cheers!
RN
I see, Thanks for assisting, RN!
To explain this a bit further:
These connections are detected on the network layer (incoming & outgoing TCP connections). PurePath data will be a subset of these connections.
Are these connections only captured if the other system has a Dynatrace agent installed?
