Infrastructure Monitoring integration with IBM Flash System
I want to ask you if it´s possible to integrate my IBM Storage FlashSystem 9xxx with Dynatrace Infrastructure Monitoring, to automate some task about changing some metrics related to the storage.
What are the methods I can use to integrated with this storage, there is an API to integrated with it, or I can use Open Telemetry, or snmp protocol
Thanks for your answers
Checking this thread, maybe it would be developing your own extension.
Best regards
