Or using terraform or monaco?
Hi @panumjp
To Manage Segments there is no API Support, you can create/manage segments via UI only using Segments App.
@panumjp Sure there is API!
Have a look at the platform APIs:
https://[env].apps.dynatrace.com/platform/swagger-ui/index.html?urls.primaryName=Grail±+Filter+Segments#/Filter-Segments/getFilterSegments
Additionally, there is incoming Segment support in Monaco, currently under a feature flag (Monaco 2.20)
Thanks @Julius_Loman for the input.
I checked the above URL and it redirected me to App Engine App Functions API which will execute the Backend Of The Custum App.
I want to know how it will help us for in managing segments. Thanks
thanks! I was able to find the API!
@zaid-bashir just chose the segments API in the combo box at the top of the swagger UI
Useful API call indeed to list the segments, I include it here to help others, my question I want to include this on a dashboard via DQL? otherwise can an API call be included in a tile on my dashboard?
<span>curl -X </span><span>"GET"</span><span> ^</span> <span>"https://<YOUR_TENNANT>/platform/storage/filter-segments/v1/filter-segments"</span><span> ^</span><span> -H </span><span>"accept: application/json"</span><span> ^</span><span> -H </span><span>"Authorization: Bearer <YOUR_PLATFORM_BEARER_TOKEN>"</span>
Thanks Julius, I am able to extract the definition of the object of the segment created in the UI, but how one can create and delete this object using the above API?, e.g. here is a segment I created manually and extracted from the GUI I need to use this as a template to create number of segments. can you help in pointing out the exact API that I should use: I list here the JSON: {
“name”: “app.environment_ops.machinetype_ops:component”,
“isPublic”: true,
“includes”: [
“filter”: “{\“type\”:\“Group\”,\“range\”:{\“from\”:0,\“to\”:84},\“logicalOperator\”:\“AND\”,\“explicit\”:false,\“explicitLogicalOperator\”:true,\“children\”:[{\“type\”:\“Statement\”,\“range\”:{\“from\”:0,\“to\”:21},\“key\”:{\“type\”:\“Key\”,\“range\”:{\“from\”:0,\“to\”:15},\“textValue\”:\“app.environment\”,\“value\”:\“app.environment\”},\“operator\”:{\“type\”:\“ComparisonOperator\”,\“textValue\”:\”=\“,\“value\”:\”=\“,\“range\”:{\“from\”:16,\“to\”:17}},\“value\”:{\“type\”:\“String\”,\“range\”:{\“from\”:18,\“to\”:21},\“textValue\”:\“dev\”,\“value\”:\“dev\”}},{\“type\”:\“Statement\”,\“range\”:{\“from\”:26,\“to\”:52},\“key\”:{\“type\”:\“Key\”,\“range\”:{\“from\”:26,\“to\”:41},\“textValue\”:\“ops.machinetype\”,\“value\”:\“ops.machinetype\”},\“operator\”:{\“type\”:\“ComparisonOperator\”,\“textValue\”:\”=\“,\“value\”:\”=\“,\“range\”:{\“from\”:42,\“to\”:43}},\“value\”:{\“type\”:\“String\”,\“range\”:{\“from\”:44,\“to\”:52},\“textValue\”:\“weblogic\”,\“value\”:\“weblogic\”}},{\“type\”:\“Statement\”,\“range\”:{\“from\”:57,\“to\”:83},\“key\”:{\“type\”:\“Key\”,\“range\”:{\“from\”:57,\“to\”:70},\“textValue\”:\“ops.component\”,\“value\”:\“ops.component\”},\“operator\”:{\“type\”:\“ComparisonOperator\”,\“textValue\”:\”=\“,\“value\”:\”=\“,\“range\”:{\“from\”:71,\“to\”:72}},\“value\”:{\“type\”:\“String\”,\“range\”:{\“from\”:73,\“to\”:83},\“textValue\”:\“ao_payment\”,\“value\”:\“ao_payment\”}}]}”,
“dataObject”: “_all_data_object”,
“applyTo”: []
“filter”: “{\“type\”:\“Group\”,\“range\”:{\“from\”:0,\“to\”:72},\“logicalOperator\”:\“OR\”,\“explicit\”:false,\“explicitLogicalOperator\”:true,\“children\”:[{\“type\”:\“Statement\”,\“range\”:{\“from\”:0,\“to\”:34},\“key\”:{\“type\”:\“Key\”,\“range\”:{\“from\”:0,\“to\”:11},\“textValue\”:\“entity.name\”,\“value\”:\“entity.name\”},\“operator\”:{\“type\”:\“ComparisonOperator\”,\“textValue\”:\”=\“,\“value\”:\”=\“,\“range\”:{\“from\”:12,\“to\”:13}},\“value\”:{\“type\”:\“String\”,\“range\”:{\“from\”:14,\“to\”:34},\“textValue\”:\”\\\“[BUSINESS_APP] E Smoketest\\\”\“,\“value\”:\”[BUSINESS_APP] E Smoketest\“}},{\“type\”:\“Statement\”,\“range\”:{\“from\”:38,\“to\”:72},\“key\”:{\“type\”:\“Key\”,\“range\”:{\“from\”:38,\“to\”:49},\“textValue\”:\“entity.name\”,\“value\”:\“entity.name\”},\“operator\”:{\“type\”:\“ComparisonOperator\”,\“textValue\”:\”=\“,\“value\”:\”=\“,\“range\”:{\“from\”:50,\“to\”:51}},\“value\”:{\“type\”:\“String\”,\“range\”:{\“from\”:52,\“to\”:72},\“textValue\”:\”\\\“[PACA] E Smoketest\\\”\“,\“value\”:\”[PACA] E Smoketest\“}}]}”,
“dataObject”: “dt.entity.synthetic_test”,
“applyTo”: []
“filter”: “{\“type\”:\“Group\”,\“range\”:{\“from\”:0,\“to\”:19},\“logicalOperator\”:\“AND\”,\“explicit\”:false,\“explicitLogicalOperator\”:false,\“children\”:[{\“type\”:\“Statement\”,\“range\”:{\“from\”:0,\“to\”:18},\“key\”:{\“type\”:\“Key\”,\“range\”:{\“from\”:0,\“to\”:11},\“textValue\”:\“entity.name\”,\“value\”:\“entity.name\”},\“operator\”:{\“type\”:\“ComparisonOperator\”,\“textValue\”:\”=\“,\“value\”:\”=\“,\“range\”:{\“from\”:12,\“to\”:13}},\“value\”:{\“type\”:\“String\”,\“range\”:{\“from\”:14,\“to\”:18},\“textValue\”:\“BUSINESS_APP\”,\“value\”:\“BUSINESS_APP\”}}]}”,
“dataObject”: “dt.entity.cloud_application_namespace”,
“applyTo”: []
