couldn’t Activate the Custom log source configuration because I got an error I have to upgrade to log v2
When trying to trigger cluster Api v2 to enable log monitoring v2 gets the following error
Hello Khaled,
I believe you don’t have access to call APIs to Dynatrace environment, you need to check with your network team for that. Try the url in postman with POST request and see the response, you should get “Missing authorization parameter” if you have access.
Islam
