Is this is on the road map or are there are any plans to fix?
I was asked to demonstrate Dynatrace capabilities for KSPM only to find that - GKE CIS missing
It happily provides CIS for AWS and Azure and standard Kubernetes.
This is 3/4 of our fleet of clusters that we can’t use this for.
I’m starting to feel that Dynatrace does not view Google as a platform that exists, this is consistent behaviour across the observability suite, where it is always treated as second rate.
Kubernetes Security Poster Management -
Kubernetes Security Posture Management — Dynatrace Docs
