Metrics expression just for fun
If you use a metric expression to get a ratio together with a default(0) option like:
var_total:default(0)/var_part:default(0)
Dynatrace will, if there is no measurement, do a 0/0! this will result in a “does not exist”.
so you better use an extra default(0) to correct this?
KR Henk
Hi henk_stobbe,
To avoid the 0/0 error you mentioned, you can use the default(1) option in the denominator instead of default(0). This way, if there is no measurement, the denominator will be 1, and any number divided by 1 will be that same number, while 0 divided by 1 will be 0 and will not cause an error.
Here is how you can adjust your metric:
var_total:default(0)/var_part:default(1)
