Hi currently running a managed Dynatrace environment. I am trying to monitor a Microsoft SQL server using ActiveGate Extension and have successfully installed AG and the extension.
Based on documentation, under connection parameters, Microsoft SQL Server extension — Dynatrace Docs, it says to provide a port number “on which SQL Server is ready to accept connections from ActiveGate”.
My questions would be
1) do I need to set an outbound connection from ActiveGate to the SQL server or is it the other way round?
2) Is there a recommended port that I should be using?
3) When trying to set the configurations, the option to input port number is indicated as “optional”. What would be the best practice here?
That would be the port on which the database is listening for queries. By default for SQL server it is 1433, but you can change it on that screen if your server is listening on another port.
What error do you see if you click on error (that brings you to the logs)? Can you telnet from the ActiveGate to the SQL server that you’re trying to connect to? Maybe there is a firewall blocking the connection.
You can find the logs directly on the ActiveGate as well. It might be easier to open a support case though. That way our support can get the log files and let you know how to resolve it.
I am trying to integrate the same MySQL extension in my managed environment, but I am unable to capture or identify the expensive SQL statements. Could you please help me with this?
