Has anyone had any experience in monitoring Huawei network devices with Dynatrace? I suppose one would be able to start with the Generic SNMP device extension, but I am curious whether anyone has created a custom extension for Huawei devices and how much more they have gained from that. Did it justify the effort of creating a custom extension?
For storage, has anyone tried monitoring Huawei storage? Would I need to create a custom extension with an API integration to the storage platform?
@derick_hewetson ,
Can’t go into any specifics, but Dynatrace SNMP extensions are very easy to create, even with Huawei devices.As the effort is so low, they really add value!
You have to grab the corresponding MIB files, and you can start here:
Hello AntonioSousa,
Can I use SNMP Generic Server extension for monitoring HPE storage sevices ??
@Doaa_Sobhy ,
The “SNMP Generic Server” is for monitoring Hosts & Servers. It’s not the best option for your case.
I would say that the “Generic network device” would be probably better for generic SNMP devices, but you would have to try it.
If you’re using HPE Alletra , then upvote this Product Idea:
Thanks for your fast response, I’ll try
Hello @AntonioSousa
“Generic network device”: provides only SNMP devices uptime, overall traffic, overall TCP/UDP traffic and TCP stats (passive opens - segment resets)
I tried “HP Nimble SAN”: provides the health state of SAN devices, interfaces and volume
