Monitoring IBM IIB 'additional instances' count
Hi all,
I am wondering if Dynatrace has the capability to monitor IIB’s number of instances in the message flow level.
This is the configuration that I’m referring to: Adding additional instances at message flow node level - IBM Documentation
The use case is to monitor instance usage and scaling it accordingly.
