Monitoring notepad.exe process
Hi Team
Is there any way to monitor the notepad.exe process and it should throw a problem alert when it is not running.
Regards
Yep you can.
Just create a declarative process group and you should see it as an usual process instance in your host/hostgroup.
Hi Dannemca,
Thank you, i am able to see the event when the notepad.exe has stopped or restarted. Do we have any way to see the problem alert ?
Regards.
For the alert, you should enable the availability monitoring on the PG
