NetworkZone for ActiveGate over Openshift
Hello.
How do I create a networkzone with the ActiveGate that was created in K8 (Openshift). I want all pods to use this AG?
I currently see pod connections to the AG in Openshift and to other Ags
Br
Jar
Hi @JAR
You can create a networkzone in the dynakube custom resource yaml. Uncommnet networkZone line and give a name to your networkzone.
# Optional: Sets Network Zone for OneAgent and ActiveGate pods# Make sure networkZones are enabled on your cluster before (see Get started with network zones — Dynatrace Docs)#networkZone: your network zone name I hope it helps.Br, Mizső
Thank @Mizső s .
So.. if I use a new NZ name , it will be unique for the AG containerized  and pods.
Correct?
Br, Jose
Hi @JAR,
It is correct in my opinion. I created netwok zones by openshift clusters level. Every single openshift (kubernetes) cluster has a network zone in my managed setup. Within a cluster pods communicate only the containerized pod (or pods - you can scale up the number og ag pods in the dynakube custom resource yaml.
Network zones | Dynatrace Docs
Br, Mizső
