OpenShift Operator - set network zone after installation
Hello.
Customer successfully installed Dynatrace operator for OpenShift without networkZone parameter.
If we define “networkZone” parameter - will Dynatrace Operator change network zone for agents on nodes, or it is need to change it manually via OneAgentCTL? Will it change automatically or not?
Thanks for any answer.
Alexander
If you change the definition of the resources, as adding NZ or Host Group, you will generate a re-deploy of the resources. The new pods would be created with the new arguments.
So there is no need to do a oneagentctl or anything… just add the definition at the yaml, apply it and openshift will do the rest.
Dante, Thanks for detailed answer.
Alexander
