Error changing networkzones Openshift
Hi.
when changing the networkzone in the Dynakube yaml file I get this error.
Can someone give me a help?
Thank you
BR
JAR
Hi @JAR
To be honest I have never changed network name in the same cluster…
Is it possible to start the dynakube install from the scracth? Maybe it is not the best parctice but I usually install the new version of dynakube from the scatch eg. today from v0.8.2 → v0.9.0. Before install delete all components of dynakube except secrets.
Best regards,
Mizső
by removing dynatrace in istio, the change could be applied
thanks anyway,
jose A
