No checkmark beside AWS Lambda function
In Dynatrace, when I navigate to the AWS section, select an account, and open the “Lambda functions” box, I notice that some functions have a checkmark in the “Service” column while others do not. Does this indicate that the functions without the checkmark have not been properly instrumented? If so, what steps should be taken to resolve this and enable full instrumentation?
Hi!
Yes, exactly.
To enable the Full Stack monitoring you can follow this guide:
Thank you.
