Hello:
This is related to com.dynatrace.extension.sql-server …
Facing below Warning messages in the Logs…The endpoint in the message is a SQL Server cluster endpoint.
While polling for endpoint xyz.integration.system.tech:2020 query have failed: always_on_availability_groups, always_on_availability_replicas, always_on_availability_databases, instance_process_cpu, instance_performance_cache_hit_ratio, instance_process_memory, instance_performance_queries, instance_performance_latches, instance_performance_locks, instance_performance_general, instance_performance_memory, instance_performance_replica, database_log_managed, database_transactions_azure, database_log_azure, database_transactions_managed
Can I know how this can be resolved, since it is causing “No data available” in the Dashboard?.
Thank you!
there’s many things still missed within the context as the following:
- did you tested the connectivity outside the extension?
- what’s the user permissions that are set ?
- what’s the extension type v1 or v2, Activegate extension or OneAgent extension?
- what’s the extension link or the extension name?
BR,
Mostafa Hussein.
Hi @MostafaHussein
Extension name: com.dynatrace.extension.sql-server ( hub/ext/com.dynatrace.extension.sql-server)
ActiveGate Extension 2.0
Regarding user permissions , Is there a Dynatrace documentation around the permissions required for a Database user of a MSSQL Cluster?
Regarding user permissions, yes there’s specific tables/views permissions is needed as the below list
- sys.dm_os_sys_info
- sys.dm_os_performance_counters
- sys.dm_exec_sessions
- sys.databases
- sys.query_store_runtime_stats
- sys.query_store_plan
- sys.query_store_query
- sys.query_store_query_text
- msdb.dbo.backupset
- msdb.dbo.backupmediafamily
- msdb.dbo.backupmediaset
- msdb.dbo.backupfile
- msdb.dbo.sysjobs
- msdb.dbo.sysjobsteps
- msdb.dbo.sysjobhistory
- msdb.dbo.sysjobservers
- msdb.dbo.sysjobactivity
- msdb.dbo.systargetservers
- sys.master_files
- sys.db_database_backups
- sys.database_files
- sys.availability_groups
- sys.availability_replicas
- sys.availability_databases_cluster
- sys.dm_hadr_availability_group_states
- sys.dm_hadr_availability_replica_states
- sys.dm_hadr_database_replica_states
also check this link for more details about needed permissions based on versions https://www.dynatrace.com/hub/detail/microsoft-sql-server-2/
BR,
Mostafa Hussein.
