Possibility to visualize data in postgress by querying
Hi i am new to dynatrace. Actually I was using grafana before for monitoring purposes. In dynatrace is there is any option to view data from a postgres table by using sql queries. As of now i could able to find the performance metrices of postgres
Hi!
welcome to Dynatrace :slightly_smiling_face: Sure there are options for both.
For metrics - just use this extension 2.0 - https://www.dynatrace.com/hub/detail/postgresdb-remote-monitoring/
For data collected using queries defined by you, you can use this extension https://www.dynatrace.com/hub/detail/custom-database-queries/ or you can create your own Extension 2.0 using the Postgres SQL data source - see more here Extensions — Dynatrace Docs
I have received the above error while establishing the postgres connection. What could be the reason? The Dynatrace Token which i have provided is taken from the ‘Access token’ tab from settings and with API v2 scope type.
Please check the log files on the activegate. Did you also unzip the extension on the activegate?
